snoko
Newbie
Message 1 of 12
2100 Graphite not working ( no line ) when plugged into ADSL filter ??
As  subject line says I cant get this to work in my adsl filter unless I plug the ph  line into the wall jack directly - which means i lose BB.
Is there a solution for this at all ( any one ) im using a filter i got with my thomson speedtouch 330 modem, and would prefer to keep it as I was told using other modems would likely reduce my bandwith due to my exchange/ line not being updated and old.
thanks
snok
11 REPLIES 11
Message 2 of 12
Re: 2100 Graphite not working ( no line ) when plugged into ADSL filter ??
Try changing the filter 🙂
Message 3 of 12
thanks
snok
Change the filter, the old one has probably failed. It will make no difference to your broadband, and the new filters are better designed for the higher ADSL2+ service.
Are you plugging the filter directly into the master socket, or are you on an extension?
Does the filter look like this
snoko
Newbie
Message 4 of 12
strange no quotes...
Keith,
Yes, my filter looks like that - an its plugged into master.
snok
Message 5 of 12
Keith,
snok
And the phone does not work when plugged into the phone socket on the filter?
In that case, the filter is probably faulty.
As a matter of interest
Which type of master socket do you have?
One of these
Or one of these
Or if you are lucky
One of these
snoko
Newbie
Message 6 of 12
Keith,
phone works without the filter , just not with it - hence the BB problem
master socket looks like pic no 1 - top
snok
Message 7 of 12
@snoko wrote:
Keith,
snok
Thanks, try a new filter. If you have extension sockets, it may be worth replacing the removable bottom section, with an ADSL faceplate.
Just as a matter of interest, have you tried plugging the filter and phone into the test socket behind the bottom section?
The faceplate may be faulty or making bad contact with the test socket.
snoko
Newbie
Message 8 of 12
No,
Im disabled so not so easy for me.
any filters youd recommend ?
snok
Message 9 of 12
@snoko wrote:
No,
snok
BT should have sent you a couple of filters when you ordered broadband.
If not, they can be ordered from the BT online shop. They are listed as BT ADSL Micro Filter RS         £5.22
Search Google for BT Shop.
snoko
Newbie
Message 10 of 12
Not with BT with an indie ISP , maybe i should check with them first .
snok
