mitsumike41
Message 1 of 2
8600 Ringtones stopped working.
I have 4 BT8600 phones and recently all the ringtones have failed except on one which still works.
I checked all the settings on all 4 phones and they were identical.
I sent a query to the BT helpdesk and received the following reply.
To Restore Ring Tones on Handset.
Reset the handset settings
  1. Press Menu and scroll upwards to Settings, press Select.
  2. Press upwards to highlight Reset, press Select.
  3. H/set settings is highlighted, press Select.
  4. Reset <handset> settings back to default? is displayed, select Yes.
  5. Resetting <handset> settings... is displayed while the reset takes place. Once finished, <Handset> settings reset back to default is displayed.
I followed these instructions and all phones now have their ringtones back and working.
Magic. A.
1 REPLY 1
PaddyB
Moderator
Moderator
Message 2 of 2
Re: 8600 Ringtones stopped working.
Hi @mitsumike41,
It's good to see you back on the community and thank you for posting.
That's really useful information for anyone else facing the same problem.
PaddyB
