Newbie
Message 1 of 2
A blocked incoming phone number that needs unblocking
I am getting severe grief from a friend who says she is told her phone number is blocked when she dials my number.
I joined the Call Protect scheme to stop many nuisance calls I was getting and it seems to work well, HOWEVER I can not find this friends number amongst my call list, which only goes back to 20th April on my phone and there are only 2 numbers showing in the Blacklist.
I talked to BT on the Chat system and was told there are no calls showing in my Blacklist.
A lot of unwanted calls have been Blacklisted, since I took this system on, so where have they gone?
I believe after this they get put in a "trash can" type of outlet.
I am told you can retrieve any number that has been put in the system and re-instate it, but it doesn't work for me.
I'm sure this factor must have been applied to this system when it was created, so wasn't it tested?
I trust there is someone who can provide a solution to this dilemma and give me a break.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: A blocked incoming phone number that needs unblocking
Hi @upmarket7 and welcome.
Can you take a look through BT Call Protect - 'How to...' guide and let me know if that helps?
Cheers
David
