Message 1 of 5
Additional handsets
I have a BT Premium phone and 2 BT 3540 additional handsets. I have registered thes with the Premium phone but they require me to set time and date. Is this possible from the Premium phone? Or is there a way to skip this step on the additional handsets?
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Additional handsets
Hi @darby1canardly  welcome to the forum and thanks for posting. I'm not sure if it is possible to skip that step on the additional handsets. I've looked at the Premium Phone (page 52) and BT3540 (page 64) user guides and do not see any mention of setting the time and date on additional handsets.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Message 3 of 5
Looks like I have been misled as I was informed that these handsets were compatable with all other BT phones. They register OK with the base but base phone can' alter time and date on additions. They do not work without this next step. But thanks for your time.
Moderator
Moderator
Message 4 of 5
Hi @darby1canardly  When registering other types of GAP handsets they may only provide limited compatibility but you should be able to use them to make and receive calls ok.
Cheers
John
Kudos”Kudos”
Message 5 of 5
Unfortunately these handsets require the time and date to be set before they do anything.
