Shareindex
Message 51 of 106
Re: Automated scam message?
Thanks gg, so the scam had been recorded and not answered live. I clicked on 1 so no problem?
Distinguished Guru
Message 52 of 106
Hi.
You were only responding to the 1571 service (click 1 to hear the message, 2 to save or 3 to delete) - nothing will apply to the actual context of the scam message.
Shareindex
Message 53 of 106
Thanks Guru,
Apologies to drag this one out.
I called 1571 and clicked on 1 to listen to the message. The scammer gave his warning message and asked me to click on 1 to continue my Broadband and landline or 2 to terminate the services.
I fell hook line and sinker by clicking on 1. That's when the BT automated voice came back with her initial directions, press 1 to listen, 2 to save etc.
That really through me Guru because I thought I had missed my chance to stay on line. I was tired just having arrived back from a long journey. I could have messed up BIG TIME if I had heard the message live. Cheers.
plusman
Message 54 of 106
Yet another one (obviously they have my number and keep trying). 01789633629 - reported and blocked.
Gizzo
Message 55 of 106
Third one of these calls for me. Different number 01705 568536. Now reported and blocked.
Lulili
Message 56 of 106
Yet another one. This one was automated. Actually sounded robotic! From 01284770726
Shareindex
Message 57 of 106
Has anyone been scammed yet after following instructions by the scam call. What is the scam? What is the aim of the scam?
Message 58 of 106
If you respond, then they know there is a real person on the end, and will add you to a "suckers" list, and you will get even more calls, so just hang up and do not speak, or press any buttons.
They will also try to extract personal information from you.
See http://bt.custhelp.com/app/answers/detail/a_id/48253/kw/scam%20calls/c/761,6077
Nothing to do with BT.
Shareindex
Message 59 of 106
Thanks for that. Appreciated.👍
cmkessell
Message 60 of 106
Sometimes these callers use non-existent area codes.  You would think that BT could add an option to their Call Protect service to automatically block such "impossible" calls!
