davidgom
Message 1 of 8
BT 1572
How do I unblock a number which I blocked by mistake?
7 REPLIES 7
Message 2 of 8
Re: BT 1572
If you login to My BT, scroll down to "Manage Your Settings".
Scroll down to "Manage BT Call Protect".
You will see a listing of blocked callers, and the Edit option allows you to delete specific blocked numbers, from that list..
davidgom
Message 3 of 8
Re: BT 1572
Thanks a million all done.Spent 1/2 hour on text talk to get answer and got nowhere.
JR011147
Message 4 of 8
Re: BT 1572
When blacklist is full, how can I delete them to add more pest calls? And once deleted, does that mean I will start receiving calls from previously blacklisted calls? thanks for any help given
pompey1898
Recognised Expert
Message 5 of 8
Re: BT 1572
Hi @JR011147,
Goto https://www.bt.com/s/apps/appspstn/index.html?accKey=9034589#/blacklist/, then log in.
It will bring up a list of your blocked numbers.  Select tthe one/s you want to delete, click on edit then delete
JR011147
Message 6 of 8
Re: BT 1572
Just checked this. By deleting them, does it mean that the blacklisted callers can then continue to call me? I have just phoned Bt and the person told me that after 24 hours I can go into my account and continue to blacklist unwanted calls!  by reading previous messages on this forum, I don't think it is quite as simple as that. Thanks for your reply - will try again to delete them and see what happens!
pompey1898
Recognised Expert
Message 7 of 8
Re: BT 1572
@JR011147wrote:
Just checked this. By deleting them, does it mean that the blacklisted callers can then continue to call me?Blacklisting a number does not stop them calling, they get sent to your junk mail. As they will no longer be blacklisted they will still ring though. I have just phoned Bt and the person told me that after 24 hours I can go into my account and continue to blacklist unwanted calls!You can always blacklist any number, up to a limit of 100.  by reading previous messages on this forum, I don't think it is quite as simple as that. Simples Thanks for your reply - will try again to delete them and see what happens!
Bryneglwys
Message 8 of 8
Re: BT 1572
Many thanks! Works a treat 👍🏻
