weejocky
Newbie
Message 1 of 3
BT-1600 Cordless Call Divert
Hi All,
I wonder if someone can help me with my new phone, which is a BT-1600 Cordless.
I don't have anyone I can call on to phone into me during setup so that I can see what is, or isn't happening.
I want to set up a call divert, to operate if the call is unanswered.
But I have the answering machine set to come on too, after 10 rings as I am a bit slow-moving these days.
Will my call be diverted to my mobile (diverted setup to do so)  and THEN to the answering machine if I don't answer the mobile, or will it just go straight to the answering machine if I don't answer the land-line ------ in which case, if I want the calls to at least try my mobile, will that mean cutting out the answering machine?
Open to all suggestions, and thanks for reading this,
Ian
2 REPLIES 2
Message 2 of 3
Re: BT-1600 Cordless Call Divert
this should explain ho call diversion works
To divert your calls, follow these instructions on the telephone line you want to divert from:
To divert all calls dial: *21*(phone number you want to divert to)#
To divert any calls you don't manage to answer within 15 seconds dial: *61*(phone number you want to divert to)#
To divert calls when your phone is engaged dial: *67*(phone number you want to divert to)#
An announcement will tell you that you've set it up successfully.
your answerphone is not used
weejocky
Newbie
Message 3 of 3
Hi John46,
So, as I thought ---- I can't incorporate the answering machine as well.
Many thanks for a quick, and helpful, reply.
Ian
