Newbie
Message 1 of 4
BT 8500 remote handset won't ring
Base hand set rings as normal. Remote handset won't ring. Been through all the settings and troubleshooting information, no joy.
I am NOT GOING TO PAY 60p PER MINUTE FOR "out of warranty technical help".
Can anyone help with this?
3 REPLIES 3
Message 2 of 4
Re: BT 8500 remote handset won't ring
Have you tried turning off the power to the base unit for about a minute?
Newbie
Message 3 of 4
Yes. Not sure whether that solved it or not. It's now working as per normal!
Message 4 of 4
It usually fixes it.
Sometimes the base to handset communications link locks up, and the base unit need to be restarted.
