Message 1 of 10
BT Call Protect - Unrecognised numbers Setting
I have a call blocker, which works fine for UK numbers.  We were getting 10/12 nuisance calls a day.  We still get 4/5 "unavailable" calls a day most of which my old BT Caller Display 2000, registers as "International", some times with a funny 00....... number. My Gigaset phone system displays these calls as "Unavailable".
I have registered with BT Call Protect to see if this will help.  In Settings there is the option to "Not Allow" "Unrecognised numbers"
My sister and her family live in Australia, so I do not want to block their calls.  If I turn off "Unrecognised numbers" will this block their phone calls?
9 REPLIES 9
Message 2 of 10
Re: BT Call Protect - Unrecognised numbers Setting
If your relatives use Skype, there's a setting which they can make to make their number recognised.
If you "not allow" unrecognised numbers, the Call Protect blocks uk and overseas callers.
From experience, unavailable is in the same class as unrecognised, for BT Call Protect.
But it lets Skype calls through, if it knows the number.
Also if you know their numbers, add it to VIP listing.
I agree about the international out of area calls.
Message 3 of 10
Many thanks for your help.  I did know that "Unrecognised numbers" might be treated the same as "unavailable" that is why I wanted to check as Call Protect uses the former term.  My sister is 89 so not a skype user!!
Message 4 of 10
Put the International number into your vip listing.
I do this with calls from US.
It's unfortunate that Call Protect doesn't distinguish between International and UK unavailable/out of area calls, as some other devices do.
However the advantage of blocking with Call Protect is that the caller is given the option of leaving a message.
Message 5 of 10
Many thanks again.  I see that I need to subscribe to BT Answer 1571 to have the VIP option.  Assuming it enables me to stop the "unavailable" nusiance calls, it is worth the money!
Your other point that it enables geniune callers to leave a message overcomes another potential problem.  I am the membership sec. of an old school association, with members all over the world.  They very very rarely phone me but if someone does I will know.  Virtually all contact is by email.
Many thanks.
Message 6 of 10
I am going to mark this topic closed.  I have had 2 days now without a single nuisance call - heaven!  The combination I now have of CPR Callblocker 108, BT Call Protection, plus BT Answer 1571 (to enable the use of the VIP feature) seems to be working.  I probably do not now need the CPR Calblocker.
Message 7 of 10
Would be interested to see if Call Protect stand alone is successful.
Perhaps you could report on progress later on.
Message 8 of 10
I put in a separate description of our issue but thought I could add to this email chain to get this problem reognised.
I have unrecognised call set to STOP in BT call protect.  However this morning I got a call from an unrecognised number.  I know this because I called the number and BT told me it was unrecognised.
This is one bogus call out of several every day of the week.  I was hoping that BT could investigate why this protection failed.  The situation is distressing - please help.
Recognised Expert
Message 9 of 10
Hi @Frustrated26,
You are posting on a year old thread that has been marked "solved".
The comments have have made are well covered, try search.
Message 10 of 10
I have not used this type of forum before and was actually directed here by BT chat line. I have started a new thread already but so far no replies. I thought I would be getting a reply from BT. My question is why an unrecognised number got through their BT call protect STOP setting for unrecognised numbers.
Thankyou for your reply I will know for next time. It looks like I am in the wrong place. I genuinely do not know how to properly raise this issue with BT. When I use the 0800 security option I am only referred to TPS with no option to explain my query.
