pompey1898
Expert
Message 101 of 301
Re: BT Call Protect
Do you have unrecognised and international calls blocked ?
biz777
Message 102 of 301
Re: BT Call Protect
I've blocked Unrecognized calls, but not International because I need to receive legitimate international calls.
pompey1898
Expert
Message 103 of 301
Re: BT Call Protect
Is 00555 the complete number ?
biz777
Message 104 of 301
Re: BT Call Protect
Yes, when I dialled 1471 all I got was 00555.
Call Protect does not recognise this number and cannot blacklist it. I fear that scammers are generating numbers which can't be blocked.
pompey1898
Expert
Message 105 of 301
Re: BT Call Protect
@biz777,
You are right.  The most common being the spoofed 10 digit geographical numbers which can't be blocked, at this time anyway.
biz777
Message 106 of 301
BT Call Protect
I'm receiving scam calls from Nigeria. How do I blacklist all calls from Nigeria but still receive calls from, say, France? Is there a way you could blacklist all calls from a particular area code?
Message 107 of 301
Re: BT Call Protect
As far as I know that cannot be done
pompey1898
Expert
Message 108 of 301
Re: BT Call Protect
@biz777,
Are there specific international numbers you want to let through ?  If so, I am not sure if this would work ?  Block international calls but, by signing up for 1571, make the specific numbers VIP.
Wilf
Message 109 of 301
Call Protect and Allowing withheld numbers through
I have call protect and set it up as follows:
Blacklist settings
When turned on, calls from numbers in both blacklists will be sent to your junk voicemail.
    Personal Blacklist    ON     No entrie in this
     BT Blacklist          ON     Does not show you what is blocked
Call type settings
When allowed you will continue to receive calls from these numbers.
    Withheld numbers    ALLOW
    Unrecognised numbers    STOP
    International calls    STOP
The View recently received calls show
    Today 21:28:53 WITHHELD    Edit Phone did not ring
    Today 21:23:42 WITHHELD    Edit
    Today 20:59:16 WITHHELD    Edit
    Today 20:50:30 WITHHELD    Edit
    Today 20:49:54 0744 xxx xxx Edit
The Phone did not ring for the listed WITHHELD entries
The 20:49:54 call did ring the phone and I took the call
Philm1
Newbie
Message 110 of 301
Re: Call Protect and Allowing withheld numbers through
I've just got call protect and have the same problem. My daughter tried to call from work and it shows as withheld even though the settings should allow it through.  She left a voicemail (1572 junk didn't register it on the system) but there's no option to accept the number. Turning off the BT blacklist option allowed a call through from the same number but that defeats the object of having their blacklist on.  Waste of time really.  I guess creating your own blacklist is the way forward until this is resolved by BT.
