joekatie0
Newbie
Message 1 of 6
BT Freelance XB2500 no incoming calls
Hi please can you help me?
Yesterday I purchased a BT Freelance XB2500 phone with 2 handsets.  I set them up according to the instructions and charged them for 16 hours as instructed.
This morning I have entered all my contacts and felt really proud of myself as I plugged them in and was able to make a call - however, I soon realised that I am not receiving incoming calls !  I have rung my number from my mobile but the phone doesn't ring at all and my mobile just ends the call as soon as I make it - it doesn't even ring !
I have been through the instruction manual online and still no answer.  I am with Sky but surely that shouldn't make a difference?  It is like it on both handsets !
Please help !
Carol
5 REPLIES 5
Message 2 of 6
Re: BT Freelance XB2500 no incoming calls
This forum is for BT Retail customers only, who have phone or broadband services from BT. Please visit the Sky forums for help here.
http://helpforum.sky.com/
There is a helpline number for these phones on 0800 218 2182
joekatie0
Newbie
Message 3 of 6
Although I have a Sky line it is the BT phone that is playing up, not the line - my previous phones were BT and they worked fine. I will check out the Sky website but if it's a problem with the phone what do I do then?
Message 4 of 6
Then all you can do is ring the helpline number, or exchange the phones if they are faulty.
Distinguished Guru
Message 5 of 6
Have you got your previous phone that you could try in its place?
If you find that it is a phone fault can I suggest that you take the phone back to where you purchased it.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
joekatie0
Newbie
Message 6 of 6
Thanks for your reply - I plugged my old phones back in and they work fine so I'll just ring the helpline again, thanks.
