timwheeler
Newbie
Message 1 of 3
BT Freestyle 650 beeping when answer phone message is left
Hi
My cat leant on the phone base and now it beeps every 3-5 seconds when an answerphone message has been left. How can i turn it off please? !!!
Many thanks Tim
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT Freestyle 650 beeping when answer phone message is left
Resetting the handset and base would probably do it (p49 of the User Guide). But that might be a pain if you have lots of contacts stored in the phone. If you do, it might be worth waiting to see if a less radical answer turns up.
tweed08
Newbie
Message 3 of 3
I found this post while searching, and then figured it out by reading around. Just in case anyone else needs this info:
This beep is called "message alert". On the BT Freestyle 650 (and perhaps other models), you have to press and hold the "backwards skip" button (just below Answer On/Off) on the base. After a couple of seconds, it will announce that "message alerts" have been turned off. See page 14 on the manual for more info.
Good luck!
