phutcherson
Newbie
Message 1 of 3
BT Graphite 1500 answer machine
the answer machine doesn't allow messages to be recorded.
It answers ok, asks caller to leave a message, then after about 5 seconds closes call and no recording is left.
The answer and record option is on and I have changed the batteries.
Any ideas?
2 REPLIES 2
Community Manager
Community Manager
Message 2 of 3
Re: BT Graphite 1500 answer machine
Hi phutcherson,
Welcome to the forum.
Sounds like a fault, how long have you had the phone?
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
po1969
Message 3 of 3
I have exactly the same problem, did you find a solution at all?
