Geordstarr
Message 1 of 2
BT Master socket help
Hello just moved into a new flat and I want getting a dial tone.. I checked the test port on the socket still not working I could see two fires hanging free,
also so which wires go into A and B slots
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT Master socket help
hi. if it is wired to standard it would be the blue/blue white and they would go on the screw terminals of the Openreach socket. best to try each separate cable in turn as one would be the income line and the other will go offvto an extension socket
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
