Squids
Message 1 of 7
BT Phone FTPP over Cat6e
Hello,
i recently moved into a new build with FTTP.
The house has been wired with Cat6e throughout, including to two Telephone points which both feed back to a cupboard with the OTN box.
My layout is;
Openreach OTN to Cat6 wall module wih a BT to Cat6 RJ45 cable.
The Cat6 between the wall module and telephone point is connected with one of the 4 pairs. (Blue/Blue+white).
The phone then connects over a normal phone cable.
However.. it doesn't work..
Any ideas?
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: BT Phone FTPP over Cat6e
Are you getting a dial tone?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Squids
Message 3 of 7
If I plug directly into the OTN I can ring out (though slow to connect).
If I plug into the telephone port through the cables the phone shows link down.
Not sure if relevant but;
When the phone is directly connected to the OTN box, the telephone light is Solid green (On OTN).
When it is connected via the cables, it’s is flashing
When nothing is connected it is solid green.
The phone is a BT8600!
Distinguished Guru
Message 4 of 7
The remote phone socket is it rj45 or standard telephone?
Message 5 of 7
ONT
Squids
Message 6 of 7
The point nearest the ONT is RJ45, the remote is standard telephone.
Distinguished Guru
Message 7 of 7
Ok. Can you try a standard corded phone into the remote phone socket?
If you open up the phone socket what terminals are the wires connected to?
