aliali204
Newbie
Message 1 of 3
BT Response 75, 'd' fault code and beeping
Every time the phone rings and we answer it the answer machine displays the code 'd' on the display and starts loudly beeping, making it almost impossible to hear the person on the phone. This noise does stop if/when we click the stop button on the machine.
Any advice would be greatly received!
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Response 75, 'd' fault code and beeping
Hi Aliali204,
I have taken a read through the userguide and my understanding of it is when your answer machine is displaying the code d, this is because it is dialling 1471 to get the previous callers details.
You could try switching off this function to see if that helps. You can do this by pressing the "1471 button and you will hear 1471 on or off and you can select as appropriate. I hope this helps.
Paddy,
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 3 of 3
Just signed up to say thanks!
I work in a reception and when that answerphone beeps whenever we answer a call, it's really distracting.
But thanks to you, it no longer does.
