gjbrunsdon
Newbie
Message 1 of 2
BT Response 85 - answering machine locked - displays 8 messages - no response from any button!!
Morning - wondered if anyone could help with the above please. The answer machine is completely locked up and you get no response from any of the buttons. I've tries powereing on and off and have tried removing the battery and it has made no difference?
It feels like it needs a complete factory re-set. but none of the literature helps you with this.
Any ideas would be really appreciated...
1 REPLY 1
Message 2 of 2
Re: BT Response 85 - answering machine locked - displays 8 messages - no response from any button!!
Welcome to this user forum. @gjbrunsdon
Its a discontinued product now, with no support,
Have you tried taking the battery out, leaving it out, then turning off the power for about two minutes.
Then turn the power back on first, then finally replace the battery.
Its also possible that the battery need replacing, and is causing a drop in voltage.
