cozza11
Message 1 of 6
BT Verve (4 handsets) - Touchtones
I dont seem to be able to use touchtones.  This is very annoying as some companies cut off a call if you cannot press 1 etc.  Is there a setting or something to make this feature work on these phones?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT Verve (4 handsets) - Touchtones
Hi cozza11 and welcome,
Which model BT Verve do you have? You can find a list of the models and userguides here. Let us know how you get on.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
cozza11
Message 3 of 6
Thanks David it is a Verve 450, I have read the user guide several times and still cannot find anything about enabling the touchtones on the handset.
I would be extremely grateful if you could come up with a solution for me.
Moderator
Moderator
Message 4 of 6
Hi cozza11,
Thanks for posting back!
Your best bet would be to get in touch with the helpdesk for that model of handset.  You'll find their number on page 77 of the user guide Smiley Happy
All the best,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
cozza11
Message 5 of 6
Thank you David.
I have looked through a few other posts, and saw one about problems with txting which gave me some ideas to try.
I believe I have now resolved the issue, through Settings, Base settings and then Dial Mode, changing the pulse mode to tone.
Have tested out and it now seems to work.
Moderator
Moderator
Message 6 of 6
Great stuff cozza11. Glad to hear it's all sorted. Thanks for sharing that.
Cheers
David
Kudos”Kudos”
