timbarrass
Newbie
Message 1 of 3
BT box outside the house
Hi all.
By the side of our house we have a pole carrying telephone wires, and what looks like a protective box intended to protect some related cabling.
The box looks designed to be buried, but is standing about a foot proud of the surface.
Currently it stops us using the hardstanding behind it for parking easily. Does anyone know who I could contact to get it sunk to ground level?
I couldn't find any reference to this anywhere, but that might be because I don't know the right terms to use.
Thanks for any help!
Tim
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: BT box outside the house
Welcome to the forum. You can contact Openreach here, but be aware that they're not known for being helpful when it comes to resiting their equipment for the convenience of others.
timbarrass
Newbie
Message 3 of 3
Thanks very much. Hopefully they will shift it -- apart from it being in the way it looks like it's got pretty battered over time.
