Toddie1982
Message 1 of 2
BT fault Upfront test
Just a curious question .....
Broadband working fine with no issies. Clicked on track a fault in BT as was just being nosey ..
I notice ovet last few weeks there has been a couple of times it says under closed faults ... BT Broadband them in Fault type it says Upfront Test.
What does this mean as I haven't raised a fault?
Stuart
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: BT fault Upfront test
Hi @Toddie1982 when you run the online diagnostics to check your line or broadband in MyBT it logs a fault on the system, there's nothing to worry about as this is normal.
