Message 1 of 5
BT line rental charge just for a landline
Is it true, if you have on a landline and no broadband at all, the monthly BT line rental  charge is reduced ?
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re:a BT line rental charge just for a landline
My understanding is you pay for what you get.
If you only want a landline that's what you pay for, if you want BB with it you pay more.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Distinguished Guru
Distinguished Guru
Message 3 of 5
Re: BT line rental charge just for a landline
The short answer appears to be "Possibly." Have a look here and click "Don't have broadband?" at the top of the price list.
Message 4 of 5
Re: Re:a BT line rental charge just for a landline
There are reduced landline deals for pensioners/seniors who do not have broadband from any ISP
Recognised Expert
Message 5 of 5
The way the line rental only qualification is worded is open to interpretation, a landline without any access to broadband, so what if you had stand alone broadband from VM and wanted to benefit from a ‘cheap’ landline from BT ( with the £7 / month reduction ) , strictly you have access to broadband ( even if it’s not with a provider that uses Openreach) so no reduction on the line rental...but genuinely no broadband then the line rental reduction should be available
