bentos
Newbie
Message 1 of 7
BT or Independent engineer
Hi,
new here,
problem...
the box that connects me to the wider world on the outside of the house has disintergrated wires are loose and therefore no phone, no internet,
is this something i can fix, need an indpendent engineer to fix or something bt have to do?
many thanks
6 REPLIES 6
Message 2 of 7
Re: BT or Independent engineer
that is Openreach property and you need to contact BT Faults on 0800800151 this is not a job for an independent engineer
bentos
Newbie
Message 3 of 7
Many thanks john so no steps and having go allowed or advisable then?
Message 4 of 7
no it is Openreach property and any attempts at repairs can leave you liable for any network equipment damage
it is down to them only
Distinguished Guru
Message 5 of 7
If you report it as a fault, then they will fix it at their expense.  If you try to fix it, but fail, they may bill you for repairing their equipment that you've tampered with.
bentos
Newbie
Message 6 of 7
Gents thanks for the heads up will just sit tight until the 6th then which is when they say an engineer will come round to fix it,
not nice living back in the dark ages though....
Distinguished Guru
Message 7 of 7
Not necessarily, openreach could deem that the enduser has caused damage by striking/knocking the box.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
