rdravia
Message 1 of 4
BT studio Plus 5100 re Battery use
Friends and/ or  BT team
We have a phone set as mentioned above. Should the handset be put to charge only after the battery runs down or is it ok to put it on the charger whenever the hand set is not in use?
Early reply will be appreciated.
3 REPLIES 3
Message 2 of 4
Re: BT studio Plus 5100 re Battery use
Leave it on the base charger when not in use. Leaving the battery to run down, too many times, will reduce its life.
rdravia
Message 3 of 4
Thank you!
Ravi (rdravia)
Message 4 of 4
@rdravia wrote:
Thank you!
Ravi (rdravia)
Pleased to be of assistance Smiley Happy
Please return to this BT Customer Care Forum, should you need any more help with any of your BT Retail services, including BT Broadband.
