Viccee
Message 1 of 2
BT1571 & Call Protect
How do I extend the ring delay before voicemail activates on the landline phone?
1 REPLY 1
Distinguished Guru
Message 2 of 2
Re: BT1571 & Call Protect
Hi. A few discussions already on here regarding this. If you have the basic BT 1571 you cannot change the ring time before answer.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
