stevemccallum71
Message 1 of 27
BT2700 handsets - call volume fades away.
My father hrecently purchased 4 BT2700 handsets & hub, but has been having problems with calls fading away (as if the volume is being turned down.) The problem appears to affect all of his handsets - one of them within a few minutes of making/taking a call, the others a little longer...it varies.
All instructions were followed to the letter when my Dad recieved the handsets - fully charged up etc. My Dad is a very light phone user so it's not as if he's rnning the batttery down either.
We know that his line/internal wiring is all good as he very recently had a brand new master socket installed (to rectify some brioadband issues).
Any advice would be hugely appreciated.
Many thanks in advance.
Steve
26 REPLIES 26
Keith_Beddoe
Message 2 of 27
Re: BT2700 handsets - call volume fades away.
Does it still fade away if you unplug the broadband router?
stevemccallum71
Message 3 of 27
Hi Keith - thanks for your reply. I'll ask my dad to try unplugging the router. Just so I'm clear, are you suggesting physically removing the broadband cable from the microfilter in the wall, turning off the router power, or both?
Steve
Keith_Beddoe
Message 4 of 27
I would simply remove the broadband cable from the microfilter. I am trying to prove whether the loss is being caused by the router itself, or broadband signal leakage into the phone.
Unplugging the cable would eliminate both possibilities. Just powering off router would only eliminate the first one.
It it BT broadband, or a different ISP?  If it is BT, which home hub has he got?
stevemccallum71
Message 5 of 27
I understand. I will ask my Dad to try it and let you knw the results. FYI, his ISP is BT - ASDL as Infinity isnt available in his area yet.
I will get back to you ASAP.
Thanks again
Steve
Keith_Beddoe
Message 6 of 27
Thanks again
Steve
If the home hub is an old home hub 1, 1.5 or 2, then there is some internal phone circuity which can fail, and affect the volume.
Any idea whiich master socket was fitted?
Single master sockets
Filtered master sockets
The filtered ones do not need a microfilter, as the phone and home hub are on separate sockets.
stevemccallum71
Message 7 of 27
...and it's a BT Smaret Hub.
stevemccallum71
Message 8 of 27
*Smart
Keith_Beddoe
Message 9 of 27
*Smart
Thanks.
If you look at my edited post, can you identify which number socket was fitted?
stevemccallum71
Message 10 of 27
I'm not at the property, so will have to ask my Dad to investigate this at the same time as trying to unplug the Smart Hub - hope to have answers tomorrow.
Thanks for all your help thus far.
Steve
