rachdun
Message 1 of 3
BT4600 does not work
I was attempting to set up the new phone today, and was adding contacts, but it somehow got to a screen stating exit without saving? It then stated yes or no - (press the left button for yes and the right button for no).  Unfortunately, whatever button I press, I can't get out of this screen - the phone has completely locked.  I cannot turn the phone off by pressing and holding down the red phone button either.  If anyone has any suggestions, I would be very grateful.
Sorry, have resolved this myself by taking the batteries out of the handset and reinserting them. As you can see, I was panicking a bit.
Rachel
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT4600 does not work
Hi @rachdun Thanks for posting back to confirm how you managed to get this fixed. It may help other users in future.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
rachdun
Message 3 of 3
Thanks John
