robartist
Message 1 of 3
BT4600 phone. Scrolling numbers
Good afternoon
On a recommendation I bought a set of BT4600 phones.
Unfortunately, they seems to have a major problem - for me, in that the display 'scrolls' numbers that you have stored in the phone book or have recently called.
I find this difficult to deal with. Because the number moves before you have seen what it is.
Is there any way to stop the number scrolling? If not is there a better phone that does call blocking but which does not scroll?
Any help gratefully received.
2 REPLIES 2
robartist
Message 2 of 3
Re: BT4600 phone. Scrolling numbers
Hi again everyone
I have looked through the manual and can't see a solution - though it may just be me not looking properly.
That being said. Does anyone have any suggestions for a good call blocking phone. We need one that rings loudly and has good quality voice , and call blocks. And which does NOT have scrolling numbers. We want to be able to read the number on the display.
Thanks for any help in choosing.
pompey1898
Expert
Message 3 of 3
Goodle is your friend
