I've just installed a BT4600 quad handset. One handset doesn't work and displays message "No base link. Check base". Any suggestions to resolve problem will be appreciated.
Thank you
John
Solved! Go to Solution.
Take the batteries out of the handset for a couple of minutes, and then replace them.
Magic! Taking the batteries out and replacing them worked fine - handset now OK. Thanks, Keith
Excellent 😀
