rajessup
Message 1 of 3
BT4600 very low dialing tone
When pressing Green call button once, the Dialing tone from the earpeice is very low and talking to anyone they sound as if they are on the other side of the room very low and tinny
But pressing the Green call button twice the Dialing ton is normal, coming out of the handeset loudspeaker, which is correct
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: BT4600 very low dialing tone
Welcome to this user forum.
That sound like the earpiece is faulty or the holes are blocked.
rajessup
Message 3 of 3
Sounds good , its still under guarantee . so back to the shop,
