Is anyone able to tell me how to unblock a number please? Thank you
Solved! Go to Solution.
Don't have the phone but after looking at the manual have you tried this.
Menu
Call Control
Block Calls
By Number
Then can you highlight the number and is there not a method of turning blocked to allowed.
Look at page 18 : http://www.ukcordless.co.uk/manuals/BT%206510%20User%20Guide.pdf
I have been through the process you describe but the options given are Edit or Delete and all that Edit does is allow a change of number.
So frustrating but thank you for your efforts and response
Ahhh, but there is your answer.
Delete the number.
When it rings again it should then come through unblocked
Well thats what i think anyway.
Try it.
Thank you ... I have done that now and just hope! I am so grateful!
