bazpunk85
Message 1 of 16
BT6600 Base unit beeping every 7 minutes
HI there everybody,
I have scoured google for information on this and am at my wits end!
Every 7 minutes the base unit for my BT 6600 twin keeps emitting two beeps. Note: this is not the main base station.
I have checked for battery issues and that is not the case. I have also turned off any message tones. Again this has not solved it. I have tried everything i have seen mentioned in  forums and no luck so far.
ANY help would be appreciated as its annoying as hell!
Kindest regards.
Tags (3)
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: BT6600 Base unit beeping every 7 minutes
Welcome to this user forum.
See Beeping message alert
bazpunk85
Message 3 of 16
I've tried that one, everything was already set to "OFF".
Thanks for the quick reply though 🙂
Keith_Beddoe
Message 4 of 16
Try removing the power to the base station for 30 seconds, to see if it goes away.
bazpunk85
Message 5 of 16
Trying it now.
bazpunk85
Message 6 of 16
No, that also didnt work.
Keith_Beddoe
Message 7 of 16
What happens if you swap the handsets over, does the beeping follow the location of the handset?
Is there any message on the phone when it beeps?
bazpunk85
Message 8 of 16
I've swapped them around and will let you know. The base station was still beeping even without the handset in it.
Keith_Beddoe
Message 9 of 16
Do you mean the charger base unit for the extra handset is beeping?
bazpunk85
Message 10 of 16
Nope, just beeped twice again. the main base unit is fine. I'm struggling to understand why this is?
