bazpunk85
Message 11 of 16
Re: BT6600 Base unit beeping every 7 minutes
@Keith_Beddoe wrote:
@bazpunk85 wrote:
I've swapped them around and will let you know. The base station was still beeping even without the handset in it.
Do you mean the charger base unit for the extra handset is beeping?
Yes, that is what is happening.
Keith_Beddoe
Message 12 of 16
It could either be the charger circuitry in the base unit, or the power unit.
I assume that the beeping stops if you unplug the power unit to the base charger unit?
bazpunk85
Message 13 of 16
you assume correctly
Keith_Beddoe
Message 14 of 16
Then its the charging circuitry inside the unit which is causing the problem. You may find that it varies depending on whether its charging the phone batteries.
Normally any beeping would be quit a high frequency, that may only be audible to younger people, but a fault condition could cause this to be of a lower frequency.
If the phones are new, you could send them back.
bazpunk85
Message 15 of 16
I think we've had them about a year.
Thank you for your help anyway Smiley Happy
Keith_Beddoe
Message 16 of 16
You may be able to get another base charging unit, from an approved spares supplier. Try the helpdesk number in the manual, they may be able to give you a number.
