thistle1314
Message 1 of 7
BT7600 No incoming calls record
I can see the incoming call numbers when the phone rings.  When I check back after the call there is no record of any incoming calls.  This has only happened this week.    Appreciate if you could give me a solution to this.  Thanks.
6 REPLIES 6
Graham-T
Newbie
Message 2 of 7
Re: BT7600 No incoming calls record
I am also having this problem
So unless I check the phone for messages every time I return to the house I have no way of knowing if I have missed a call.
I have tried reset, and tuning power off, disconnecting and powering back up but still not cleared.
Has anyone got an answer to the problem
huntwr
Message 3 of 7
We also have this problem. Did you manage to find a solution?
huntwr
Message 4 of 7
Again, we have this problem. Did you manage to find a solution?
cinders59
Message 5 of 7
This has started happening to me since last Oct as I have had my phone for 18 months it is out of warrenty and they want me to ring an 0906 number, which I am not prepared to do.
Antne got any ideas?
huntwr
Message 6 of 7
Dear cinders59,
Sorry for the delay. I finally managed to crack this problem by deleting the entire calls record. It's almost as if the memory buffer is full and won't accept any further information. Go into the calls list, select options and then delete all. It worked for us. Good luck.
Regards,
huntwr
cinders59
Message 7 of 7
Thanks huntwr  was just going to post a reply I had from emailing them with the instructions 🙂
