LesleyR
Message 1 of 6
BT8500 Twin
Hi
Can anyone help with a problem I have with my 2nd handset. The display screen lights up at random times for no reason. In the middle of the night it lights up the whole bedroom and it's driving us nuts. Any idea what might be causing this?
5 REPLIES 5
leshay
Message 2 of 6
Re: BT8500 Twin
Hi
Yes, I have the same issue. I get spurious 'light ups' fairly frequently. Most of the time it happens it displays 'line error - please correct', sometimes no message - I suspect that when there is no message, it is because the 'error' has cleared very quickly.
Regards from Livingston, Scotland
LesleyR
Message 3 of 6
Re: BT8500 Twin
When it happens the display stays lit up until I lift the handset and replace it again.
leshay
Message 4 of 6
Re: BT8500 Twin
Hi
When it happens with me, if there is a 'line cord error' message displayed, then for whatever reason, the error clears and the phone goes to the BT logo screen for the usual timeout period and the reverts to the screensaver.
If, as sometimes happens, the screen lights up and seems to go straight to the BT logo screen for the usual timeout period. In these cases, I think the 'line cord error' did likely occur but cleared immediately.
LesleyR
Message 5 of 6
Re: BT8500 Twin
What is a line chord error? I don't get any messages at all and it doesn't ever revert to the screens average until I lift and replace the handset.
leshay
Message 6 of 6
Re: BT8500 Twin
Hi
I don't know what it is, and can't find out. There are others who have the same/similar.
