dscotcher
Newbie
Message 1 of 2
BT8500 additional handset will not connect to base
I have just bought the BT8500 and set them up for charging. I came back to them 12 hours later to find the additional handset had no display and kept flashing on and off. I can't access any menu on the phone as its loosing connection all the time. I read about resetting all the bases so did this. The phones display came on and I was able to reset everything. However once I connect the base handset (handset 1) it reverted back to flashing intermittently as if it's searching again. Anybody else had this problem? I even set the phones side by side to enable them to connect to each other!!!
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT8500 additional handset will not connect to base
Hi dscotcher,
Sorry about that, did you get this sorted? If you need any help I'd recommend you contact the BT8500 Helpdesk
Neil
