Cholet27
Message 1 of 4
I am looking to buy this model of phone. Can anyone tell me how many handsets it will support? My current system of BT phones is base station plus 5 additional phones (1 in office remote from house) with a BT repeater. I would like to replicate this system with the call barring facility. I am not sure if I can buy 2 base stations, 1 for office, 1 for house, then make up the required number of phones? This might make the calls clearer in the office.
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: BT8500
Welcome to the forum. From the user guide:
Cholet27
Message 3 of 4
Re: BT8500
Would the phone work with a BT DECT repeater? There is no model number on the instruction manual. It says it is compatible with BT Diverse 7110 etc and Diverse 6210 etc.
Beagle2722
Newbie
Message 4 of 4
Re: BT8500
The DECT REpeater only works with the Diverse 7000 + range
