Message 1 of 1
BT8600 handset won't connect to BT8500 base
I am trying to connect a new BT8600 handset to an existing BT8500 quad system.  The registration goes perfectly until I input the system PIN, when the phone gives the messsage, System PIN incorrect.  I have reset the base to factory defaults, but the pin 0000 is still no accepted.  Has anyone else had this problem?
