Message 1 of 2
BT8600 phone
I have the twin set of the 8600 phone, the problem is when people ring us, they are getting the ringing sound at their end of the line at least 4 times before it rings at our end. The problem is by the time we answer the phone our end it has switched to BT answer service. How can we either get phone to ring immediatly at our home end or extend number of rings before switching to BT answer. Thank You
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT8600 phone
Hi @Terryjw  sorry you are having a problem with your BT8600 phone. Check out the help page BT8600 Advanced Call Blocker and as well as the user guide the contact details for the product helpdesk are listed.
Cheers
John
