Primper52
Newbie
Message 1 of 3
BT8610 twin set
Loud screeching noise from phone after a message has been left.
Only had phone a couple of days so when this happens I have been switching off at socket then back on to stop the noise.
Not handy if no one at home. I would appreciate any help.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT8610 twin set
Hi @Primper52,
I'm sorry to hear about the problems you've experienced. It's best that you speak with the Product Team for the BT8610. You can find user guides and their contact number at the following page:
BT8610 Advanced Call Blocker
DanielS
Primper52
Newbie
Message 3 of 3
Re: BT8610 twin set
Thank you for your quick response I have emailed BT if no success I will give them a call
Regards.
