Jawm
Message 1 of 2
Barring calls
Hi. My parents currently have a phone where if the number isn’t known you have to state your name and then they decide if they want to take the call. Is this system on the actual phone or is it through BT?
1 REPLY 1
Message 2 of 2
Re: Barring calls
Hi @Jawm   It is on the phone. It will be a nuisance call blocker or call guardian phone. They work with all providers, the only requirement is caller ID must be activated.
