susanj2308
Newbie
Message 1 of 2
Big 100 phone
how can I increase the number of rings before the answer machine kicks in?
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Big 100 phone
It doesn't have a built-in answer machine; if you have a separate one there may be advice in its user guide.
If you mean the free 1571 service, that is set at 7 rings and can't be changed. To adjust BT Call Minder, see here
