simplyme
Message 1 of 5
Blocking All Outgoing Calls
Ordered BT Infinity 1 late last week, once service is up and running can all outging calls be blocked for free or is that a chargeable facility.
4 REPLIES 4
Message 2 of 5
Re: Blocking All Outgoing Calls
why would you want to block outgoing calls as you get free weekends calls and using a phone regularly can avoid many broadband problems
simplyme
Message 3 of 5
Only phone calls I make are 0800 from mobile
I have my reasons for wanting to know whether outgoing calls can be blocked/barred withut charge within Infinity 1 service
Message 4 of 5
call barring is chargeable
Distinguished Guru
Message 5 of 5
Ensure there is no phone plugged into the line.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
