Sue036
Message 1 of 3
Blocking Calls from Unrecognised Numbers
Hi, I have BT Call Protect and, having had numerous calls today from unrecognised numbers (all from a machine purporting to be my internet provider), I have altered my settings to block calls from unrecognised numbers.
I am now wondering if there is any risk that this will block any calls that I DO want?
Thanks for any advice.
Sue
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Blocking Calls from Unrecognised Numbers
Hi, @Sue036 welcome to the community and thanks for posting, that may be a possibility but the caller will be directed to your junk voicemail box so if it is a genuine call they have the option to leave you a message which you can listen to by dialling 1572.
Sue036
Message 3 of 3
OK, thanks, I didn't think of that!
I'd best get into the habit of checking for those messages, then.
