zulligs
Newbie
Message 1 of 3
Broadband/phone conflict
Turned my computer on Saturday evening after getting home from work (was fine when I left for work that morning), only to find no broadband connection....................Long story short discovered only way to get a connection is if I have my phone on, turn off the phone and I lose the connection. I have my phone on now as I am writing this.
Can anybody help the helpline in India is of no help and I can not check my connection while the phone is on
thanks
zulligs
2 REPLIES 2
Message 2 of 3
Re: Broadband/phone conflict
Follow the instructions here first
http://bt.custhelp.com/app/answers/detail/a_id/32908/c/346
They should give you an idea where the problem is.
If you still have problems, then report back here.
Distinguished Guru
Message 3 of 3
Hi, this problem is normally due to a line fault or a faulty ADSL filter. Suggest you locate you main socket and plug the bnr direct into the test socket
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
