natalie77
Newbie
Message 1 of 5
Bt converse 2100
i am using one phoneline in my office. I used to be able to pick up the main ward phoneline using the r and m1 button. that stopped working when i accidently unplugged the phone. how do i reinstate this feature
4 REPLIES 4
Message 2 of 5
Re: Bt converse 2100
Welcome to the BT Residential Customers forum
I am assuming you are a business user, so please could you post on the BT Business forum at http://business.forums.bt.com/
As I expect that its either a PBX or Featurenet problem
natalie77
Newbie
Message 3 of 5
i have already been through the buisness section and they keep telling me to come back here. all i need is someone to talk me through how to program the phone hand set. it is absolutley not a problem with the line.
Message 4 of 5
This is only a customer to customer help forum, so all I can suggest is this help page
http://bt.custhelp.com/app/answers/detail/a_id/12412/~/bt-converse-2100
There is no additional support for this product.
If you have someone who maintains your phone system, then they may be able to help, as its possible that a wire has become disconnected.
There are many types of recall  methods used by PBXs, some use short line break, and others use an additional wires.
Page 9 of the user manual suggests that its just a short line break, so that would point to an issue with the phone, the recall buttion itself, or the PBX.
Also see
Switchboard compatibility
This product is intended for use within the UK for connection to
public telephone network and compatible switchboards, which
support tone dialling and timed break recall.
Your BT Converse 2100 can be set to work with your switchboard
by moving the switch on the underside of the base to either
P (pulse) T (tone) or TB (timed break). If in doubt, please consult
your service provider.
Could you have moved the switch by mistake?
Distinguished Guru
Message 5 of 5
It would always depend on what type of phone system you have in your office as the pickup code required for you to answer the call would vary. Suggest you get on to who ever does the admin on your system to request they give you the code required. You could then programme this on the required button on your phone.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
