Dehane
Message 1 of 3
Bt6500
Hi I have brought 2 second hand handsets but am unable to reset the pin numbers as it asks for pin when I try to register them and then no link to base comes up when I try to reset them to the factory oooo if that makes sense thanks
2 REPLIES 2
spacepilot
Message 2 of 3
Re: Bt6500
try searching and downloading the user manual.
this is a previous fix
Re: BT 6500 unknown pin - not 0000
on ‎29-12-2013 18h44
Hi
Taken direct from the user guide.
1. Select
Menu, scroll to display Settings and
press
Select.
2. Press to highlight
Reset and press Select.
3.
H/set settings is highlighted, press Select or press
to highlight
Base settings and then press
Select
4.
Reset <handset or base> settings back to default?
is displayed, select
Yes.
5.
Resetting <handset or base> settings… is
displayed while the reset takes place. Once finished,
<handset or base> settings reset back to default
is
________________________________________________
welcome to the world of last wednesday week.
there's now't wrong with 2 cans and a piece of string. at certain times, it is often faster.
Dehane
Message 3 of 3
Re: Bt6500
Done that every time it registered the hand set it asks for pin which I don't know then when I try to reset it says. No link to be base thanks
