AIB5
Message 1 of 10
Bt8500base handset
Bt 8500. When I press key on base handset, screen goes black and keys are dead. Batteries showing fully charged. Other phone ok. This is a twin pack. I’m fed up of it.
9 REPLIES 9
Message 2 of 10
Re: Bt8500base handset
Welcome to this user forum.
First take the batteries out of the base handset, then wait about a minute, then put them back in. See if that helps.
How old are the phones?
AIB5
Message 3 of 10
Thanks, already tried several times, including new batteries. My next shot is to try the old unplug and put the the plug back in.  Not tried that one yet. You know, technology is great when it’s working properly or you have the knowledge. But when it isn’t and you do not have that knowledge, it can be a pain.  😁😁 I am 71 but learning all the time Keith. Thanks again and hope your household have nice Christmas and New year. Thanks  🎄🎄
AIB5
Message 4 of 10
Sorry forgot to mention (age)😀😀Phone about three years old. Possibly should retire it.
Message 5 of 10
I think you have probably tried all the other things I would have suggested, including replacing the rechargable batteries.
Have you tried swapping the handsets over to see if the base handset works on the extension charger base, just in case there is an issue with the base unit charger?
It could well be a hardware/software issue with that handset, there are places that do sell additional handsets which you could pair up with your existing base. Look on a well known auction site, as it may be worth a try.
AIB5
Message 6 of 10
Cheers Keith. Thanks for your suggestions.
Tony. Doncaster
AIB5
Message 7 of 10
Hi Keith. Finally got, 8500 call blocker sorted. It had been turned off for some reason at the Provider's end. Now blocker working perfectly. Thanks for your help and info. Tony AIB5. Doncaster. Cheers.
AIB5
Message 8 of 10
Hi.  Problem with 8500 base handset sorted, by me. I had not used the proper rechargeable batteries. And you must use the batteries specified in the handbook and all is now well. I’m a happy bunny. Still, my best wishes to BT Customer Support Ennerskillen. The Best. 👍🏻👍🏻👍🏻👍🏻  All of have a Great Christmas and New Year.
AIB5
Moderator
Moderator
Message 9 of 10
Hi @AIB5,
Thank you for posting back. I'm glad your been able to get the 8500 working.
Merry Christmas and a happy New Year.
PaddyB
AIB5
Message 10 of 10
Thanks Keith. Hope you and your colleagues and families have a Great Christmas and New Year.
AIB5
