bayardmm
Message 1 of 3
Call Protect problem
Like countless other people I’m constantly bombarded by scam calls, and like others I subscribe to the Call Protect service. However I now find that I cannot put any more numbers into my blacklist due to it being full. My quandary is, which numbers to I delete to make way for new insertions. No doubt deleted numbers will be recycled. What’s the point of the service if out blocked numbers are limited?
2 REPLIES 2
pompey1898
Recognised Expert
Message 2 of 3
Re: Call Protect problem
I, like numerous others, have complained about this limit.  To add insult to injury one can only delete numbers one at a time which is extremely time consuming.
Maybe one day the mods will pressure BT into increasing the number ?
youlethal
Message 3 of 3
You should delete the oldest ones first as most of the time these are recycled numbers. If you are getting a lot of these calls maybe look into getting a phone which can block the numbers without the need to use 1572 or the call guardian feature can be useful as well to deter these people from annoying you
