Message 1 of 10
Call already in progress but no call has been made or recieved
So earlier my dad asked if I was using the phone which I wasnt & it turns out that we cant make or receive any calls at the moment because the handset says 'Call already in progress.  Join call?' I've tried hitting the hang up button & calling the house phone with my mobile but nothing is affecting it, the last unrecognized number is '07377089904' which according to google is some Indian one.  Obviously while this is going on we cant use the phone at all, hough the internet is unaffected, though it does seem a bit slower than usual with google taking a few secconds to appear as opposed to almost immediatly as I'm used to with infinity.  As well as that I'm also seeing the message 'line cord error' some of the time from the handset, I dont know if theres a connection between the 2 or if 2 unrelated things have happened at once.
Please make the response simple to understand as I have trouble reading these days due to disability so making it easy to follow would be appreciated
9 REPLIES 9
Message 2 of 10
Re: Call already in progress but no call has been made or recieved
Welcome to this user forum.
If its a cordless phone, then turn off the power to the base unit, wait about 30 seconds, then turn it back on.
If its just a normal wired phone, then unplug it, then plug it back in again.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements. If there is noise, then you may have a fault on your line, that would cause thin line cord error message.
Message 3 of 10
I unplugged as suggested then plugged it back in & called my mobile, the call time started going up as normal but my mobile did not ring & showed no sign of any incoming call also no sound of ringing as you'd expect while waiting for someone to pick up came from the house phone.
Just tried dailing 17070 twice, the first time I just got a sound of rattling like a rattlesnake was in the room & the second time I got only silence and now after a fourth try the 'line cord error' message is back
Message 4 of 10
Then you have a fault on your landline. Report it to BT as no dial tone or a very noisy line.
That will affect your broadband as well.
Its a good idea to check at the test socket with a known good phone first, to make sure its not your phone or wiring.
Message 5 of 10
test sockets dead as well, whats the link/number for reporting the fault?
Message 6 of 10
0800 800 151
Or https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=2&s_cid=con_FURL_faults
Message 7 of 10
efficient bunch, they found the fault & said it should be about 5 days to get fixed, would be quicker but xmas is in the way.  There was me expecting to be waiting til January as well, pleasntly suprised by that
Message 8 of 10
They are quite quick, as they would be working Monday, Thursday and Friday, so it depends on how many faults Openreach have in their queue.
It will be an external faults, sound like water has possibly got into the line, as the incoming ring is being tripped, which is why you do not hear the ring tone when you call from a mobile.
If you could please update this thread, when the fault is cleared. Thanks.
Message 9 of 10
an engineer came out today & so far everything seems to be working as normal now which is good
Moderator
Moderator
Message 10 of 10
Hi @Hawq,
That's great news.
If you notice any issues, or need any other help, please let us know.
DanielS
