Newbie
Message 1 of 6
Call protect
After signing up to call protect all incoming numbers now show up as unknown  number. Any ideas why or what I can do to rectify this ? Thanks
5 REPLIES 5
Message 2 of 6
Re: Call protect
Welcome to this user forum.
Possibly the change has caused caller display to be removed by mistake.
See if its still enabled
Is the facility switched on?
If you've ordered Caller Display check it's switched on by entering the code * # 234 #.
If it's active you'll get the message Caller identity will be displayed. If the facility isn't active then activate it using the code * 234 #.
If its not, then it can be added free of change using this link.
https://secureorder.bt.com/consumerOrders/control/orderproduct?productId=CON-27455&productKey=CON-CH...
BT Privacy and caller display, is near the top of the options on that screen.
It takes about 24 hours to re-activate.
Newbie
Message 3 of 6
Re: Call protect
Thanks, *#234# service not available so I have re-ordered caller display.
I shall let you know the outcome .
Distinguished Guru
Message 4 of 6
Re: Call protect
Hi @Mrstrow,
The order to turn it back on should have completed. Can you test it and see if it's working please? Smiley Happy
DanielS
Newbie
Message 5 of 6
Re: Call protect
Sorted, thank you. 😁
Distinguished Guru
Message 6 of 6
Re: Call protect
That's great news @Mrstrow,
Thanks for letting us all know Smiley Very Happy
Have a great weekend
DanielS
